what do now
what do now's Avatar
12.05.2009, 06:54 AM
Tell me about it- lack of upto date/ item specifc images has always been a pain in the r/c world, makes me have to 2nd guess everything I look at sometimes.
The last 2 pictures you posted especially make me think those are combos and not hybrids- the hole/ recess for the bearing to sit in should be exactly the same on each half - Im gonna assume when you tried fitting the bearings that came with your 1/8 diffs, one side was fine, the other isnt even close (not just a tight fit which is normal, but a good 1mm or more too big to fit)?
If thats the case, FLM should sort you out, but getting hold of them is a pain quite often. Just keep the emails civil to avoid them blanking you..
Thanks for the info.
And yes your right, one side is fine the other is way off.
Last night I managed to find the invoice that came with them, it doesn't say if its a Combo or Hybrid but it does have a product Number FLM10200 & 10300. Nothing on the FLM website about them, I did find an link from there old site mentioning the number, but of course the link is dead. Only other place I can find anything about these numbers are from Stormer Hobbies, https://www.ssl-stormerhobbies.com/c...ns&pn=FLM10200 It says Hybrid, but I'm not too sure, doesn't give any details.
Have sent a nice email to FLM, including the pics, so hopefully they get back to me.
Actually just found them at RC Bros aswell?
http://www.rcbros.com/cart/scripts/p...?idproduct=231
