Unsullied_Spy
Unsullied_Spy's Avatar
12.06.2009, 07:22 AM
Originally Posted by shaunjohnson View Post
from memory that is one step too far.
for me, that screen comes second after you have already selected and option.
it usually says to hit R for repair.
I think the one you're talking about is the repair console/command prompt. I haven't done this in a while, but I think you select the volume which XP is installed on and it will detect that there is a current install and should ask if you want to do a repair install. I did this a few times years ago and on some installs the option wasn't there.
Have you tried booting into Safe Mode? If it is a software problem then booting into Safe Mode should work.
