12.07.2009, 03:57 AM
Well, What gearing do you want to use?
If you plan to use std set screw style pinions they only go up to 25t. I use a 23t pinion and the 63t TiN Losi spur with the tdr single speed hub. If you use the tdr motor mount you will not be able to use much less than a 23t pinion as the adjustment will not allow the motor to get any closer to the spur.
I would suggest buying the tdr motor mount, and his single speed hub. Make sure your desired motor/battery combo will allow you to use a 23-25t pinion and you can stick with setscrew pinions from rcm. They are the best pinions to use with the Tin spurs that losi offers. You can get a 59t spur, but you will have to use the 25t pinion, no smaller.
If you need larger than 25t pinion get the tdr colleted adapter, and use the 2nd gear rcm thread on gears he sells to go with his 2 speed adapter hub. They are the same thread as the tdr colleted adpater.
If any of that makes sense I will eat my hat. It is late and I am in full zombie mode.
