Semi Pro
Semi Pro's Avatar
12.07.2009, 04:29 AM
Originally Posted by 76Bentley View Post
The best I have found out there is from "The Dude Racing" He really does beautiful machine work and it is a very cleaver design, very similar to the motor mounts in on road card that have a center that rotates for the gear mesh and then locks down.
http://www.tdracingrc.com/
Here is his website, he just did a run for the LST mounts, the single speed conversion he makes is nice too.
+1 on the dudes mount
if i were you i would run the single speed, all i know is the hard shifting lst transmission destroys rear diffs if you are useing a big motor on 6 cell
i watched mikey84 go threw 6 properly shimmed diffs this year (sure he could of adjusted the slipper alittle but he doesnt listen and he's bigger than me! )
also right now his stuff is on sale ( 20% off) untill jan 15
we are useing the rcm pinion adaptor for the kyosho inferno gt 2 speed, its let u use the stock nitro pinions, they are cheep and last along time
