Pdelcast
Pdelcast's Avatar
12.07.2009, 01:55 PM
Originally Posted by Thomas Porfert View Post
It will not include a 1s LiPo cut-off, that is something I will be talking to the engineers about; I'll
You assume correctly. Because we've had to disable the onboard BEC for 1s operation, you will need to supply external power to the receiver. That can be done by using a separate power source like a 2s LiPo with an external BEC or a 4/5 cell receiver pack. You can also boost the voltage using a product like the Novak Smart Boost.
Thomas Porfert
Castle Tech Support
Clarification -- "Custom" cutoff voltages (through Castle Link) will be available for 1-cell range, but there will not be a stick programming option other than "Auto-Lipo" or "Disabled".
Patrick del Castillo
President, Principle Engineer
