Disagree. -
12.08.2009, 09:02 PM
As for fireprrof you are most likely correct, but the fridge does have about 2" of foam in the sides, so it may be a bit fire retardent.
I would have to disagree with you there James. Fridges are the worst in fires. They are made mostly of plastic and once the fire gets to them the styrefoam insulation burns like crazy and gives off poisinous fumes that can kill you. Fridges go up like fire logs unless it is a metal encasement fridge/freezer.
