thzero
12.09.2009, 10:15 AM
Wow, yes sir, whatever you say sir.
However, it is nice that you've tried it and were able to give feedback on it. I originally made the suggestion based on moving to Big Joes from stock X tires and had to regear slightly because of the larger size. And the Terra Pins are slightly bigger, but probably not quite as heavy either.
P.S. Scamming a quality company like HPI isn't cool, all one does is hurt the company when doing that.
Originally Posted by fastbaja5b View Post
They make no descernable difference to the motor or esc temp and eagletree amp draw went up from 120 amp peak to 124 amp peak.
If anything the motor came off cooler
And that was in the middle of a 90 degree day.
