coolhandcountry
coolhandcountry's Avatar
02.01.2006, 10:20 AM
I run a 10 k oil in my center diff daniel. That seems to work will. I used ue oil to. I am not sure on the stock diffs you have for they only have the 4 spyder gears in them I think. That would require the thicker oil for the same effect as the 6 spyder diffs.
Could you explain on the difference between the other two companys. Like is it thinner or thicker. And what have you tried with results you got.
Peace!
Country
Help support the
Rc-Monster
Buy here
