Do you guys know that the Slash 4x4 plat is 16th scale.....
if you dont
Motor: Traxxas Velineon 380 brushless motor with Neodymium magnets, sintered rotor and high RPM ball bearings, 3.5mm gold plated bullet connectors
Suspension: Revo-spec rocker actuated long travel inboard type with telescoping universal joint shafts, front and rear swaybars and separate extra stiff swaybar set
