brushlessboy16
brushlessboy16's Avatar
12.11.2009, 08:03 AM
Originally Posted by ASYSTEMERROR View Post
I started with the FLM nitro chasis converted it with the kershaw stuff it Looked dumb stripped it put nitro stuff back on bought another savage roller when i picked it up it was FLM nitro chasis powdercoated black with kershaw mount and battery saddles. Now from this point i should have toughed it out and purchased ONLY flux parts like mounts,motor plate, and i would have saved money but i stripped and sold the nitro chasis cause i had one already and now i have the trannyforward setup. i kinda understand what your doing i have a bunch of aluminum chasis braces and some stuff i know will get the job done for you. If the tranny is fitting between the tvp's and you just need to mount the motor plate i have these half mounts FLM provide to mount various plates between the tvp's they sent like a few extra with the parts i have ordered over time. does the flux motor mount bump the tvp if you move it out to far ? or is it where the plate mounts go there's no frame material to mount to.
The flux motor mount does not fit the xl tvps plain and simple.
and I wish that the transmission was about an 8th of an inch lower, so i dont need to clearance the entire plate to clear the driveshafts
