12.15.2009, 02:25 PM
Go with the td racing single speed hub. This eliminates the one way bearing in the 2 speed and will allow you to use the motor for the brakes. You will also be able to use reverse. Only way to get rid of the mech brakes.
You can install a mech reverse setup out of the lst and unse a 3rd channel servo to select it, however you will still need to use the mech brakes.
