Thread: Castle 1717
riverat1540
riverat1540's Avatar
12.15.2009, 09:34 PM
Just be carful if grinding down the shaft to 5mm not to let the flat spot let you throw the shaft off whack while grinding as it will cause the bit to hop if not stabilized. Then u will have a pinion that meshes funny as the shaft is no longer centered.What link did is about the best way short of cutting it with a lathe.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
