simplechamp
simplechamp's Avatar
12.16.2009, 04:55 PM
Thanks! The open bulkhead design is definitely a big plus for maintenance and adjustments.
The other thing I am debating is that I have one sway bar set right now, and I'm not sure to put it on the front, back, not use it at all, or maybe get another set and run both front and back? Is there a standard setup that should be tried first? Once I get it up and running I'll have to experiment a bit.
