12.16.2009, 08:57 PM
Originally Posted by ta_man View Post
RPM limiter is unrealistic. It won't solve the problem (even if all the manufacturers agreed to put one on) because it is not just about RPM but power output. You ought to know that, Brian. You would need different RPM limits for the different motors. Way too complicated for no real benefit. The RPM limiter they use now is the wind of the motor and it works better than anything else.
It was more of a sarcastic tongue-in-cheek response. I think this whole thing is ridiculous. For a given voltage, a motor can only spin so fast. Period. The thing here is efficiency. So, because other companies don't/can't make a controller that is as efficient, CC has to suffer? It's not like they're using a switching step-up power supply or anything. And it's not about who has the most money wins since the MMpro1s is cheaper than just about everything else out there.
If they want to regulate it that much, they should just hand everyone the car they want people to use and be done with it.
