Pdelcast
Pdelcast's Avatar
12.16.2009, 09:03 PM
It was more of a sarcastic tongue-in-cheek response. I think this whole thing is ridiculous. For a given voltage, a motor can only spin so fast. Period. ALl the other bells and whistles simply make the motor go as close to kv*voltage as possible. The thing here is efficiency. So, because other companies don't/can't make a controller that is as efficient, CC has to suffer? It's not like they're using a switching step-up power supply or anything. And it's not about who has the most money wins since the MMpro1s is cheaper than just about everything else out there.
If they want to regulate it that much, they should just hand everyone the car they want people to use and be done with it.
Actually Brian, we are making the motor go way above Kv*V, by using some timing and commutation tricks -- So they do have a point. But we didn't start it, LRP and Tekin had variable timing way before we did. We just took it a little further, and added some commutation tricks in...
We are also producing a lot more power -- for example, a 21.5 turn motor with fixed timing produces about 108 watts at the 50% efficiency point (I know- - the design of the motor is TERRIBLE!) We are getting about 190 watts output from the same motor at the 50% efficiency point, by changing the timing and commutation method.
If the ROAR motor wasn't so badly designed in the first place, we wouldn't be able to use software "trickery" to make the motor perform better (at least not by the same magnitude...)
Patrick del Castillo
President, Principle Engineer
