SnoopMaxx
SnoopMaxx's Avatar
12.17.2009, 05:08 PM
I punched the no. in to Brian's calculator
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 18
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.005
Spur/Pinion Ratio: 2.56 : 1
Total Ratio: 8.45299 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Rollout: 1.67:1
Total Motor Speed: 37000 RPM
Vehicle Speed: 58.6 mph (94.13 km/h)
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
If you use a 22T you should reach the 60mph you want
Morten SnoopMaxx
Never to old to play
c",)
