Thread: Jammin SCRT10
Update
Shark413
Shark413's Avatar
Update - 12.19.2009, 02:02 PM
Started working on putting the kit together. Added a Mamba Max and Neu 1509/2D motor. Good news is most of the parts are the same as the CRT.5 so I am moving over a bunch of cnc parts (steering rack, spindles, c-hubs, wheel hex, etc). This also means replacement parts will be easy to get since the CRT.5 has been out for a while. Bad news (at least for me) is that the Battery will only hold a 2s lipo pack. I guess this is ok if you will be running a smaller brushless motor and 2s, but I want to use my Neu 1509 on 3s. I was running the Neu and 3s in my modded CRT.5 and it was a rocket and ran very cool, so I moved my custom carbon fiber battery tray over to the SCRT10 so I could use a 2s or 3s battery.
Optional parts
CRT.5 compared to the SCRT10
The Neu 1509 is slightly bigger than a castle 5700 motor.
My custom battery tray, uses the existing holes in the chassis.
Here is a Protek 2s and a Losi 3s all 5000mah. Only the 2s will fit in the stock tray. My Reedy 2s hardcase also fits in the stock tray.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
