SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.21.2009, 06:24 PM
Originally Posted by Lauri View Post
I'd like to hear some settings for 17.5T stock 1/10th Sedan Touring 2S LiPo. What are good CHEAT mode starting settings for the class?
The thing is I normally run modified and no need to use CHEAT mode there (actually using another ESC). But one race will only have 17.5T Stock so I wanna try the MMP ;)
For the novak motors, which have the sensors preset at 30 degrees, I've settled on about 15 degrees advance starting at 8-10k rpm. +18 degrees is too high. Gearing is 33/72 on the xray T2 platform, and temps are right around 160-170 after a 6min run plus practice laps.
Set braking force at 100%. Even drag brake should be set at 100%. The brakes are really weak. Punch control should be disabled.
Area 52 Ranch Raceway
T.R.C.R.
