Helly
Helly's Avatar
12.22.2009, 02:55 AM
Thanks all for your interest!
To suicideneil: you right, it's a 5T
The rear center driveshaft is huge ! Did you make it yourself ?
You won't use a skid to protect it ?
Yes it's a homemade driveshaft with juste a aluminium tube between classic revo shaft and two screw to hold them...
for the hub, i forget to add this pic: (it's just 23mm hub with around 0.4mm plate to add the extra 1mm!
