Pdelcast
Pdelcast's Avatar
12.22.2009, 04:07 AM
Originally Posted by J57ltr View Post
So why wouldn't you just plug directly into the usb port on the mm instead of using the card?
Jeff
Well, you can. But the MM is the only controller with a USB port - -for any other controller, you would need either the programming card, or a USB adapter to program with a PC.
The idea of the card is that it allows programming with a PC on ANY controller, and quick programming at the field without a PC.
Patrick del Castillo
President, Principle Engineer
