ReV:-O
RC-Monster Carbon Fibre
12.22.2009, 10:26 AM
if you solder on 12awg wire, arn't you limiting the current flow? i mean, it must come with 8awg for a reason, no?
i've got a pair of Neuenergy 5000mah lipos at the moment, and i did a poor job of soldering on the deans. The power I get from them is not as much as I should be getting, and i'm also getting 45 minutes of runtime whereas i should be getting around 20 minutes. i think its because due to my bad soldering, the current has been reduced.
