gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
12.22.2009, 03:06 PM
Ah, I see. I put in 30K I believe, which has been much better. My front and rear probably needs more fluid, it's about time for a change. I want to put 10K in the front and like 4 or 5K in the rear. I was also thinking about 7K up front, I'm not sure which would be better.
It's going to be different with each setup. I run a direct drive setup with motor brakes and a slight drag brake so I don't have to slow down much using the trigger in corners. The droop helped tremendously. My front end was so high when accelerating that I could hardly control where the truck was going when on power in corners. This is the first 1/8 scale that I've actually fine tuned for racing, so it's been a fun learning experience.
:D
