Thread: Jammin SCRT10
Shark413
Shark413's Avatar
12.23.2009, 01:40 AM
Originally Posted by johnrobholmes View Post
Dang that is a sweet looking rig! If I picked up a short course truck, this would be it! I bet the 1509 is a screamer.
How much room do you have on the chassis for the battery? I am wondering if a 6s 2500mah system pack could lower the CG.
If I remember correctly the stock Batt tray interior dimensions are 6"x1"x2". My custom tray is a little more open and allows for a larger battery all the way around. Where you have an issue is if you go too wide you run up onto the mudguard mounting bumps. You are right about the low mah 6s it would probably be smaller/lower. But I have a bunch of 3s I recovered from my dead 4 and 5s 5000mah Zippy's.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
