Thread: E-Maxx Diffs
Serum
Serum's Avatar
02.03.2006, 06:16 AM
I run mine on a 7XL fine.
the question is.. For how long..
You need to maintain the diffs very good, need to re-shim them every now and then.
If you keep the gears mesh tight, they should be fine.
It's always nice, to have a bit of overkill in strength in the drive-line imo.. (with certain BL, it can be rather hard to create an overkill though)Anyone who is complaining about the power of the hv-max, you should see it on 4S lipo, it is a serious racer on 4S. And to tell you the truth, i do like the mounting of the esc.. The 'drop in' factor is very good on this setup...
