DCastaneda
Speed Addict
DCastaneda's Avatar
12.24.2009, 11:52 AM
Mine is setup like so:
Front:
80wt oil
10k diff oil but am going to try something stiffer
Green springs
droop at arms level
black sway bar
just a very slight amount of toe out to eliminate turn-in (makes it less touchy at high speed)
Rear:
80wt oil
light diff oil (1-3k is fine)
Purple springs
droop at a little past arms level
silver sway bar
standard 3degrees toe in
Center diff J-B Welded together.
Now for some pics of the new look, dubbed Miami Vice
  Send a message via AIM to DCastaneda
