Originally Posted by Serum
You can use relative long screws, the M3 is tappered right thru, so you could use the size you like, as long as it doesn't touch the screw that holds the sinnglespeed plate.
Are we even talking about the same thing? I have the FLM half case it came with 3 hex screws and they are to long and will not go in all the way to hold the blue motor plate.
