02.03.2006, 03:51 PM
All you've done is installed your diffs the wrong way round. You should be able to reprogram your controller to spin the motor the other way. If you've got a warrior, just plug your batts in and pull out the red programming jumper (on the controller), and when the motor beeps, put it back in. This will change the motor direction.
