12.28.2009, 02:51 PM
I've run mine quite a bit and haven't managed to do anything more than break the tires loose from the wheels a few times because it has more power than the glue could handle \m/. The stock NiMH batteries make it very slow, if they have experience driving something faster drop down to the speed pinion and run 12 cells or get them 2s lipos. I run 2x 2s Hyperion G3 VX 1800 mAH lipos in parallel with the speed pinion (for longer run times) and it gets a pretty decent top speed, cool temps, and 30-40 minutes of full throttle use.
