12.28.2009, 07:32 PM
Originally Posted by jokerjustin View Post
i cant really feel the actual battery as it is enclosed.. it came with a wallwart charger... is there a way to check if it is a "smart" charger?
You'll feel heat through the case if it's getting hot.
You'll have to check the instructions on the charger. Does it say to unplug it after the 36 hours? Then it's not. If you can keep it plugged in it is.
Does your r/c charger have an sla option?
