12.30.2009, 02:50 PM
So, if I pick up the ring/pinion set, I can slap it on the existing diff cup and the alignment on the stock buggy bulkhead will mesh right?
EDIT: Are the diffs in the MBX6T and MBX5T the same? I was just browsing ebay and it seems MBX5T parts are getting scarce. Or, are they ring/pinion gears from different vehicles that will work? Also, I noticed the truggy diffs are helical cut. I know this places a large thrust load on the bearing, so I'd really like "regular" gears.
