Thread: Mmp f1
hooppjs
RC-Monster Stock Maggot
hooppjs's Avatar
12.31.2009, 12:31 AM
64p spur and pinion? I hope they hold up to brushless power
Hi _paralyzed_,
Instructions say 25T.04 & 104T.04. Pinion is steel and the spur is the same hard plastic as the Landmax spur. Cannot remember what the material is called, but it's very strong.
Should hold up fine since the tires will constantly break loose anyways... 'Won't be much strain on the gears if they're spinning.
Good job fitting it all under that body!
Thanks What's_nitro?,
I will be experimenting with the Pro's punch control for sure. Car weighs 1045 grams, with battery. The MMP was fitted without the sidepods on the F1 too.
Peter
100% recycled electrons were used in this message.
