02.03.2006, 07:33 PM
The MGM 80 and Feigao 8s motors are both listed on the site. This is probably the motor/controller combo that would best meet your needs. The MG can run numh batteries with the Lipo safety setting, too, so it really isn't necessary to re-program if you run different battery types. The Lipo safety is the important feature. With the proper gearing, this setup will be very good to you. You may even consider a Feigao 380c motor(which I will get listed over the weekend in the store. The 380c6L motor comes to mind for your application. :)
