Erevocanuck
01.01.2010, 08:52 PM
Originally Posted by hoober View Post
12 amps is what you spec. If you'll put up with 10 amps (there's many chargers with a 10 amp limit) then for 2S you may like the 989 MRC superbrain. For 3S you might like the Checkpoint TC 1030. There are also many Chinese chargers that will do 2-6S at 10 amps. (i-chargers are one)
Alot of the lipo battery companies say not to use the MRC chargers because they don`t use the constant current/constant voltage standard of charging
