sikeston34m
sikeston34m's Avatar
01.01.2010, 10:41 PM
Originally Posted by shawzie View Post
Hey guys,I bought two of these packs
http://www.hobbycity.com/hobbycity/s...C_LiFePo4_Pack
and would like to make it into one single pack.How hard would it be to do this?My soldering is pretty good and my pack making skills are good but I have never touched one of these flat packs and when I looked at the inside there is a little board in there.Will it be a pain in the a$$ to do?
Hi,
One quick and easy way to do this would be to get a 4S balance plug. Or if you don't mind dealing with two balance plugs, you could leave them as is.
Remove the shrink from both packs.
Remove the Power leads from both boards.
Place the two packs side by side, and attach the two packs together with double sided sticky.
Then Solder the positive tab, (the one that you removed the power lead from), to the negative tab of the other pack.
You can use a short piece of 10Ga. wire for this, since there will be a short gap to cross.
Solder the Power leads back on, noting polarity. Red goes on Positive, Black goes on Negative.
Verify Polarity with a test meter.
Reshrink the entire pack with much larger shrink.
Charge, install in RC, and have fun.
I hope this helps.
PS Be VERY careful not to short anything. This could cause hair loss and a really nasty spark.
