ANGRY-ALIEN
ANGRY-ALIEN's Avatar
01.02.2010, 02:44 PM
Continuing with the experiments... I was getting a little concerned again about the temps and them getting higher when I eventually switch over to lipos.... so I decided to make some changes
with ESC setup and pinion to see if I would get better results... and I did... I remembered when I was first testing the hacker, the 'Torque Selection' was change from 'Soft' to Dynamic Initial Torque'...
So I went back through the Quark programming and changed the initial torque to 'Normal 1', one step above 'soft'... I swapped the 15t pinion for a 18t just too see what would happen... this motor
had so much torque I assumed it could handle the gear up... I was not wrong about this, The motor showed off what it could really do with it's power and pulled the truck just as hard when it was fitted with the
15 tooth... Very impressive to say the least... the temps were also surprising... the esc only got to 112° F (well it had some help from the heatsink)... I thought it would have been much higher with the
larger pinion... the motor stayed in the high 120s
The setup:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 18
Total Voltage: 18.5
Motor KV: 1600
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.83 : 1
Total Ratio: 12.18333 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.46:1
Total Motor Speed: 29600 RPM
Vehicle Speed: 40.84 mph (65.6 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
CC 1520 with a 18t pinion
I'm going to run it on 5s tomorrow and see it goes... going to also try and get some vids done too (good quality I hope).
Alien
