01.02.2010, 03:14 PM
You need the wire to stick up at least 1 inch for optimum performance. I usually use a radio box or a mount that also has a antenna tube holder, then just cut a short piece of antenna tube to hold the wire. I leave it under the body, so it stays safe if I flip over.
