01.02.2010, 03:25 PM
You need the wire to stick up at least 1 inch for optimum performance. I usually use a radio box or a mount that also has a antenna tube holder, then just cut a short piece of antenna tube to hold the wire. I leave it under the body, so it stays safe if I flip over.
Upon further inspection, it looks like I have just enough wire to use a sm. mount and sm. amount of tube where the mount is now
