sikeston34m
sikeston34m's Avatar
01.04.2010, 08:42 AM
The setup got changed around again.
This time, with the goal of getting amp draw down to a decent level while maintaining a good level of performance.
The setup is:
E Revo
MM Pro (lowest timing, 100% punch control)
5S 20C 5000mah Turnigy
Medusa 36-70-2000 geared 14/52 (around 35mph)
This setup performs well. Top Speed sees the motor spinning around 38000rpm.
I tried this setup on 4S (Top Speed 28mph), and the graph from it is almost identical to the 5S Graph. Hmmmmm.......... I wonder what it would do on 6S? Don't have the 6S setup at the moment, but it does have me curious.
Most of the spikes are right around 65-70 amps. This should be accurate for the logger since it isn't exceeding 100 amps.
