brushlessboy16
brushlessboy16's Avatar
01.04.2010, 01:24 PM
Originally Posted by whitrzac View Post
make sure to make a recess in the top in order to get a hex into the pinion
already have that. need to mill a portion in so that the shank of the pinion will slide in- I know Im having a tough time getting pinions to fit on my 2200(shortened shaft)
As for clocking the motor- your limited to about 30degrees each way- or i would need to make a custom top plate for 45 degree mounting.
My idea now is tho have the actually motor plate clockable- 10 degree increments or so.. but making a devoted 45 degree mount is more practical and would cut down on machining time and less waste material...
