01.05.2010, 10:09 PM
Neil, that looks sweet.
As far as why the holes are not true...I do a lot of drilling at work and if the chuck is not EVENLY tightened, the hole will be off just a bit..and that is just one reason. The drill press I use is older so the chuck/and or the shaft that holds the chuck is just not true anymore. Can be frustrating as hell at times.
the one thing that does help is to slow the press down a bit and drill very slowly but even that doesn't always help
