sikeston34m
sikeston34m's Avatar
01.06.2010, 07:24 PM
Yes, it can, but only if you are testing continuous current ratings.
When you start testing bursts, it gets a little tricky. You know that the PWM signal for an ESC is 1ms (rev/brake) - 1.5ms (neutral) - 2ms (wot). So, you already only have 0.5ms to play with when going from neutral to wot (rev/brake is not used). If you "cap" the ESC throttle at say 50%, you then only have 0.25ms to play with. Now, you are really reducing the resolution of the signal so when trying to make tweaking adjustments, you may not have enough resolution to adjust the output exactly where you want. The use of an aircraft ESC may help with this since it doesn't have reverse and so it has the full 1ms of throttle range to work with. Personally, it would be easier to make load modules so that each one is X ohms, and you just parallel what you need to get into the ballpark.
I hope that made sense.
Yes, it does make sense.
Sounds the resolution on such a pwm controller will have to be very precise. I see your point.
I think the initial goal will be to measure and graph a constant amp load.
You're looking at imitating the current demands of a Monster Truck, aren't you?
I've noticed with the Eagletree results, average current draw is really very low, But those spikes! My but those spikes are many times more than the average current draw.
I would like be able to adjust the amp draw to a preset level. Just like some Lipo manufacturers do.
Here's how the voltage per cell that's held under a 20 amp draw, a 50 amp draw and 100 amp draw for the life of the discharge cycle.
Then, here's how many mah's were used during the discharge cycle.
In noting differences in how Lipo cells are rated, it's not only the "C" rating number they love to "toy" with, but it's also the actual mah capacity of the cell.
Both the "C" rating and the Mah rating, drastically affect the performance of the cell.
One thing about the Eagletree, it's really easy to hook up a temp sensor for ambient, then another temp sensor for pack temperature.
All good information to record when it comes to testing.
We need a good system to use as a "measuring stick", then we can let the tests roll!
