GriffinRU
02.04.2006, 02:30 PM
Originally Posted by rhylsadar
@GriffinRU
i don't get your argument. the plettenberg maxximum might be compared to the L series. maybe. from all i read and saw it is pretty much more powerful. but the bigmaxximum suerly plays in the same range as the XL motors.
a lehner 1930 is in the range of a maxximum. the 1940 or 1950 are more on the bigmaxximum level.
yes the pletts are 4poler which poses some problems sometimes.
the schulze controllers can to 63'000 rpm with 4polers and double the rpm with 2polers.
i am also pretty sure that the lehners are 2polers.
bye
rhylsadar
My comment based on overall dimensions. Check side by side picture. Plettenberg motor dimensions are closer to L-series then XL. But has extra features in the can design, which makes it run cooler and overall setup makes it run with better efficiency (in limitted RPM range!) then feigao/nemesis/hacker.
Artur
