George16
Supermaxx
George16's Avatar
01.07.2010, 04:44 AM
You're not landing correctly if your bottoming out hard with a 70wt oil. I have a revo conversion running on 5S with the Castle Neu 2200Kv and I don't bottom out hard. I'm using silver or white springs (I'm color blind) in the rear and green springs in front with 50wt oil all around. I try to land like the airplanes do (rear landing gear touching the ground first and then the front) and I found out that the rear will not bottom out as bad as landing on all four wheels at the same time.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
