Pdelcast
Pdelcast's Avatar
01.07.2010, 12:43 PM
Originally Posted by kazuaki View Post
1) What the heck could cause this?
2) Obviously the ESC is toast, but should I be worried about the motor? In the Slash 4x4 the ESC and motor are pretty close together and the endbell of the motor is blackened from the fire.
3) Is there any way to be sure my lipo is OK? It doesn't have any visible damage and it still reads full voltage.
Unfortunately, at these power levels when anything goes wrong, the ESC usually takes the brunt of failure -- and at these power levels the failures are usually spectacular.
It sounds like the ESC took the damage, I wouldn't worry about the motor -- it's probably fine.
If you Lipos show normal voltage, they are probably fine too.
Contact tech support by phone, and let 'em know I told you to call in. We'll see if we can expedite your service.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
