01.07.2010, 06:24 PM
Everything looks pretty dang good except the Motor/ESC choice, even running on 6s is questionable.
Motor Specs:
12-32 NiMh or 4s to 8s Lipo cells in a 30"- 40" mono or hydro.
1400 - 1800 Watts Maximum with proper cooling.
45mm Diameter x 76mm long
5mm Output Shaft for use with 5mm Couplers.
25mm Mounting Hole Spacing. Uses 3mm screws.
545 grams
Recommended rpm range 25k - 35k RPM.
2-Pole Neo Magnets & Compressed Windings
