01.08.2010, 12:33 PM
The MM and Quark (old XXXB line) use linear regulator, which have a lower dropout (~0.3v), so that makes sense. But I'm sure you realize that the supply voltage HAS to be somewhat higher than the BEC voltage, or the BEC voltage will drop. If it drops low enough, it simply shuts off.
