lutach
lutach's Avatar
01.08.2010, 03:00 PM
Originally Posted by t-maxxracer32 View Post
man you make it sound so easy! are you talking about CD investments or long term stocks or what?
i would like to start saving like you mentioned because i would love to retire at 50 with a few hundred thousand in savings.
so it sounds as if right now the stock market is not the wisest decision.. i have a few other tricks up my sleeve in how to use my money.. nothin terribly illegal
anyways i appreciate all the help!
If you do your homework you can make some $$$. I was going to mention a risky stock to you, but if it went down, I would've felt bad. The best thing is to do your research on good companies that pays dividends. Keep them for as long as you can and you should retire in good shape. The market might go down again, so you should play carefully. I know a lot of guys that makes a good chuck of change day trading, but it can be very addicting specially if you're making money. Try and keep out of the Pinksheets, OTC or Penny stocks. The company I was going to mention was GM or MTLQQ which was somewhat low and going down everyday, but the news came out with the new GM battery factory that started production, the stock went up. You can make some money there, but you can also loose it all if the company you invest in gets out. A good example can be found in the stock game a few of us are playing. I bought some CIT thinking it would stay there for a while, but man I was wrong. Lost a good amount of money there.
