Thread: Tire choices?
_dV
01.08.2010, 05:51 PM
V0RT3X: Took the new wheel\tyre out for the first time yesterday for a short run. It was only on flat ground though, no jumps.
I have run with these tires taped briefly on smaller diameter wheels and air control was fine. A little more sensitive than other wheels i have run which was probably due to the higher relative mass of the tires to the truck. I've also run taped badlands and air control was great.
What happened when you taped your road rages that made air control terrible?
There is a lot of ballooning on 4S with the Flux.
