Originally Posted by skellyo
Not sure where you got that weight from... The longer TVP's are only 1.5lbs more than the stockers. Where do you see another 2 1/2lbs coming from in that kit? The TVP's are the only significant item in the kit to contribute to increased weight.
I emailed them about weight and the said the kit weighs 2.15ozs, sorry for my typo and that might be Shipping weight ?
Bondo: Also keep in mind that anything other than a 15xx Castle/Neu motor can is going to need a different mount because of the can diameter.
The mount will not be a problem, If I have too I can make one myself. Also have a friend of a friend whom works at a metal shop w/a CNC machine
I greatly appreciate all you alls input but no 2 posters have had the same suggestion nor much for straight answers ?
Whats the best viable option weither I run 6s or even 8s
1527 motor but what KV ? ?
ESC, Castle Ice 200 ? ?
