03.16.2005, 06:21 PM
The cable plugs into a printer port on the computer. The plug on the controller that plugs into the receiver plugs into the program cable on the other end, along with a receiver pack. There are only a few settings that can be programmed on the warrior controllers. I haven't played around a lot with the timing (my controllers are set to automatic timing, which optimizes the timing throughout the run). basically, you can play with these settings as you wish, and save each saved setting as a file to retrieve later (like when you find the setting that works best, you can then add it to all your controllers). I assume you downloaded the instructions as well? Also, make sure you don't reverse the connectors (controller and rx pack) when you plug it in to the cable.
